A little help please
Permabanned
22 Dec 2010
West Lothian
Hey guys i recently just finished putting together my first build on Tuesday and besides a little problem with temps which i sorted by applying thermal paste properly everything has been ok...up till now:(
Basically since Tuesday i have had 4 blue screens,twice trying to install Everest once attempting to install another ati program and the last one which was about 5 minutes ago trying to run Skype which until then i had no trouble running.I have not attempted to overclock or anything yet and the only thing i have changed is the core voltage which i tuned down from 1.21250 to 1.10125 to drop temps a little bit.I'm running w7 64 bit with a i7950 and a asus sabertooth motherboard,also got Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel ram and a 850 watt psu.temps are between 28 - 34 idle and 44 max load.please could someone tell me whats up?
Thanks
problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 2057
Additional information about the problem:
BCCode: 1e
BCP1: 0000000000000000
BCP2: 0000000000000000
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\032411-19468-01.dmp
C:\Users\muzza\AppData\Local\Temp\WER-25069-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
With Blue screens the first thing to look at is memory. Also, why drop voltage, those temps are not high at all?!
Used to run Memtest back in the day, not sure if thats still the tool of choice for memory testing.
they were a little higher then that before i applied thermal paste properly and dropped the voltage,also the first three times happened before i dropped it,the last time being five mins ago trying to start up skype.Thanks i will give it a crack.
is 1.10125 a little too low?,my memory voltage is 1.3000 is that ok?
Ran Skype 2 mins ago no problem,need to wait till tomorrow to run memtest don't have any spare Cd's to burn too lying around.
