A little help please
10 May 2012
North London
OK so can anyone give advice or comments on the krk kns 8400 headphones please ?...they would be being used for music production.....they are for my 15 year old daughter.
thanx .
If she doesn't mind going open back the K612 would be a better choice as it's bass to mids to treble transition is linear in fashion. The K8400 wouldn't actually be too bad as it doesn't puss out on bass bloat but the bass is elevated and the response is a little rollar coaster so your mix won't come out how you want it unless you learn the sound of the phones and work around it.
If open headphones are out of the question due to room noise etc then it's hard to recommend most closed headphones as they either have too much bass or too much treble. A lot of the time the mix will come out too lean and bright,
Just my 2cents.
OK thank you for your advice Ryanr..thats informative and helpful :)
But being like her Mother lol..shes made her mind up and gone for the KNS 8400.
