A little help selecting case/psu/cooling please
25 May 2010
I currently have a Cooler Master Elite 335 case that I bought when I put my pc together in 2011. Since then I have added some bits and pieces and its getting a little cramped. Also my PSU (Antec 620w) has started to make a clicking noise under load in some games.
I am after a new case that will accommodate a MSI P67A-G45 motherboard, ssd, hdd, Xonar Essence sound card & 2 x 970gtx's. Idealy I just want something quite plain and without a window or led fans.
Also I am looking at water cooler for my cpu (2500k) as I have been running it at stock and want to give it a bit of an Overclock to 4.2-4.5ish. When I did OC the chip to just 4.2, the extra noise from my fans dealing with the heat was not worth it.
I would also need a new PSU as my current one is non modular and has wires everywhere, also it's started to creek under the strain of all the other gear.
I have my PC in my front room and sometimes game on the TV, so I would like to try and keep the noise down if possible.
I have a budget of about £200ish I can go a bit more, but would prefer less if at all possible :)
Would appreciate any assistance, thanks!
