A little help with a spec please
13 Jul 2003
ok so im looking for a small form factor system similar to what ive spec'd below. IVe put it in GH because i have a few more general questions about it
1 - do you recomend i get a better CPU cooler
2 - is the motherboard a bit over kill if im not going to do much OC'ing
3- i have a xp 32 licence is it worth going to the vista ive speced below
4 - am i right going with radeon ive heard they have a had a few driver issues.
5 - would it be worth me getting a modular PSU so i dont have to many cables running around the little case and is the PSU suitable.
ok questions over . I will be using a dvd drive from my current spec as well as anouth hard drive to serve as a bk up. Thank you for any halp you can give me, it been a while since ive done a spec.
Powercolor ATI Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail Powercolor ATI Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
(£117.49)
Intel Core 2 Quad Pro Q6600 2.40GHz Guaranteed to run at 3.00GHZ (1333FSB) - Retail Intel Core 2 Quad Pro Q6600 2.40GHz Guaranteed to run at 3.00GHZ (1333FSB) - Retail
(£124.54)
Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939) Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939)
(£62.26)
Gigabyte GA-G33M-DS2R Micro ATX (Socket 775) PCI-Express DDR2 Motherboard Gigabyte GA-G33M-DS2R Micro ATX (Socket 775) PCI-Express DDR2 Motherboard
(£70.49)
GeIL 4GB (2x2GB) PC2-6400C5 800MHz Black Dragon DDR2 Dual Channel Kit (GB24GB6400C5DC) GeIL 4GB (2x2GB) PC2-6400C5 800MHz Black Dragon DDR2 Dual Channel Kit (GB24GB6400C5DC)
(£49.34)
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ)
(£90.46)
Lian-Li V350B Aluminium Mini-Tower - Black Lian-Li V350B Aluminium Mini-Tower - Black
(£90.46)
Akasa AK-P040FG8-BKUK 400W Green Power 80+ Akasa AK-P040FG8-BKUK 400W Green Power 80+
(£51.69)
Sub Total : £558.92
Shipping : £10.95
VAT is being charged at 17.5% VAT : £99.73
Total : £669.60
ditch the "guaranteed clock" cpu, they're a waste of time over buying the normal one.
vista 64bit would let you use all of your RAM, 32bit XP won't
that card is the best card for the money out.
having a modular psu is up to you, if i was speccing a build, though, I wouldn;t have chosen a 400W psu for that card, a Q6600 2 HDDs and an optical drive.
cooler's up to you, I'm not sure how much space would be in that case, but the stock cooler should be okay for 3ghz, there might be quieter (and cooler running) alternatives. you'd have to get case dimensions.
In relation to point 4. my 4870 won't give a DVI signal to my Dell TFT (I'm currently using a DVI to VGA adapter). This is a definitely a driver issue without a fix to date - I'm not sure how widespread this problem is, but one to keep in mind.
