A little help with this code please!!!
6 Mar 2009
I am trying to write this C++ code which will sort a 2D array, but not sure what parameters to pass when im calling it in the main. Here is the code.
Code:
#include<iostream>
using namespace std;
int d[3][5]={{1,2,3,4,5},{10,1,2,1,5},{3,1,3,4,2}}; // array to sort
 void selectionSort(int *array,int length)//selection sort function
	int i,j,min,minat;
	for(i=0;i<(length-1);i++)
		minat=i;
		min=array[i];
      for(j=i+1;j<(length);j++) //select the min of the rest of array
		  if(min>array[j])   //ascending order for descending reverse
			  minat=j;  //the position of the min element
			  min=array[j];
	  int temp=array[i] ;
	  array[i]=array[minat];  //swap
	  array[minat]=temp;
void printElements(int *array,int length) //print array elements
	int i=0;
	for(i=0;i<= d[3][5];i++)
    cout<<array[i]<<endl;
void main()
    selectionSort();                 //call to selection sort
	printElements();               // print elements
	system("pause");
	//return 0;
Thanks
You will need to call the array that you want to sort. I take it you want to sort the three differrent rows of numbers individually?
In that case you will want to call each row individually which can be done with a simple counting for loop as below.
Code:
     int k;
     int lengthOfArray = 5;
     for (k=1;k<=3;k++) {
         selectionSort(d[k][5],lengthOfArray);
         printElements(d[k][5],lengthOfArray);
Hope this helps, I am no expert :p so may be completely wrong!
Edit: my mistake you will also need to pass the length of the array to the selectionSort and printElements method. You can look at the sizeOf() function to establish this.
What line is the error referring to? You are setting 'array' as a pointer by using the * character before it. Unfortunately I am not sure why you would need to do this, due to my lack of experience.
Im getting an error on both selectionSort, and printElements where the d is.
I found most of this code online and not sure what some for it does either.
The methods are expecting a pointer to (i.e. the memory address of) the array. Use the 'addressof' operator (&) to pass in the address of the array:
Code:
   selectionSort(&d[k][5], lengthOfArray);
   printElements(&d[k][5], lengthOfArray);
Whenever you see a '*', read it as 'a pointer to'. Whenever you see a '&' then read it as 'the address of'.
[edit] just noticed something else. You want to use '&d[k][0]' rather than '&d[k][5]' to sort the array from the start.
Hmm, the bit that doesn't make sense to me is:
Code:
for(i=0;i<= [b]d[3][5][/b];i++)
It's less than or equal to the array? I believe it should be the length of the array here.
Code:
for(i=0;i<= length;i++)
Sorry here is the more updated code. I changed a few bits.
#include<iostream>
int i,j,min,minat;
minat=i;
min=array;
min=array[j];
int temp=array ;
array=array[minat]; //swap
array[minat]=temp;
int i=0;
for(i=0;i<=4;i++)
cout<<d<<endl;
int main(int *array,int length)
int k;
int lenghtOfArray=5;
selectionSort(&d[k][0],lenghtOfArray);
printElements(&d[k][0],lenghtOfArray);
system("pause");
return 0;
