a little help!
22 Jul 2009
ok was just about to click buy on a new bfg gtx 275 ocx but then ive suddenly realised about the psu required to power it!
on the bfg website its saying that a minimum of a 680 psu is needed.
i have a 530 psu but ive seen some people running gtx 275s with 500 psu's
whats going on? do i need to upgrade my psu aswell?
530? Is that a Tagan one?
If so, I have the same one and I'm running a GTX280 with lots of other bits absolutely fine.
A decent 400 watt would do it.
You should be fine but you may need to use a molex-PCI-E cable. Make sure you connect it up properly and you will be OK. I am pritty sure the card will come with two, but it may be worth checking.
