So i have been putting up with this problem for quite a while now but its becoming a nuisance. My computer will randomly crash not blue screen but just die. The screen will freeze where it is and the only way to get around it is a manual reset. I have re installed windows a good few times and that doesn't help i have ran memtest86 and that never comes back with anything.
I recently upgraded my graphics card, cpu and psu but the problem was happening before this.
My current specs are
Phenom II X4 965 BE
Asus M4A78LT-M
8GB DDR3 @ 669MHz
AMD Radeon HD 7700
Seagate Barracuda ST3500412AS 500GB
If anyone could point out the problem or give me a hand that would be a massive help.
Thank you.
Phenom II X4 965 BE
Asus M4A78LT-M
8GB DDR3 @ 669MHz
AMD Radeon HD 7700
Thank you.
