A little Photshop help?
26 Mar 2005
I want to use an image for a design on a t-shirt, its just that I need an irregular shape from a normal shaped image, that's pretty easy right? Any tips would be welcome, I'm playing around with the wand at the minute, I can't seem to select the entire shape, its always bits.
It might be easier to see what you mean if you post the image in question. Have you tried using the magnetic lasso tool or the polygon lasso tool?
