A little php help please
If you're using PHP, then just echo it only if the URL matches:
Code:
<div>foo</div>
<?php if ($_SERVER['REQUEST_URI'] == 'http://example.com/example.html?querystring=value') : ?>
<div>bar</div>
<?php endif; ?>
<div>baz</div>
There's no need to include the div in the markup if it doesn't need to be displayed :)
Code:
<div>foo</div>
<?php if ($_GET['querystring'] == 'value'): ?>
<div>bar</div>
<?php endif; ?>
<div>baz</div>
Would be cleaner and better I reckon.
It might however give you a notice if you're using E_ALL for error reporting...
so maybe:
Code:
<div>foo</div>
<?php if (isset($_GET['querystring']) && $_GET['querystring'] == 'value'): ?>
<div>bar</div>
<?php endif; ?>
<div>baz</div>
