A little upgrade.
29 Nov 2004
Was thinking about upgrading a little..
- 2GB to help out with Vista and Gaming, to make 4GB total.
£49.34 GeIL 2GB (2x1GB) PC6400C4 800mhz
- CPU fan, atm it gets over 65c underload @ 3ghz.
- I'm also looking for stuff to clean and polish CPU so I can apply some AS5.
Current spec
EVGA 680i
e6600 (stock cooler)
2 GB Geil PC6400 PC6400C4 800mhz
BFG 8800GTX
fine if you are using a 64bit OS. Otherwise, only 3.2Gb (approx) is seen by the system.
what are you using at the moment?
You can buy TIM cleanner but a bit of denatured alcohol or nail varnish does the trick nicely.
@ Huddy.. 64bit yes and stock cooler.
Thx for tips guys, but the cleaners seem cheap enough, but which one...
Akasa or Arcticlean?
lol, I was almost sure i had stock cooler... just looked and I ain't, I got Artic Freezer Pro 7. Thought it was stock cooler because it hardly ever goes below 60c.
