hi!
i was looking into making a diy watercooling system for my CPU and GPU since ive read that watercooling kits are rubbish. you can see my system specs in my sig. i have a 4890 and its very loud. Here are the components.
CPU/GPU block
I can get a EK 4890 GPU block for that. I'm a bit confused about which CPU block to get. I have AM3 socket and they are identical to AM2 sockets so I suppose any cooler which supports AM2 will do. Anyone have any idea?
The Reservoir and Pump
I was looking at this one: XSPC Dual 75- Bay Reservoir and Pump? Any suggestions on that?
The Radiator
There are 2 good companiesm thermochill, swiftech and XSPC. Any ideas on which radiator to get. I have a HAF 932 case so the radiator can be screwed nicely on the top part of the case. The case can take dual or tripple radiator. And by the way these radiators shown on the OcUK website, do they come with fans? or would I have to buy fans separately and install them on the radiator?
And the setup?
I have never had any experience with LCS's before and I'm a complete newbie. I've read how to setup a LCS with just the CPU, (make circuit, radiator to cpu, cpu to pump, pump to radiator) but I want to liquid cool my 4890 aswell. What should the circuit look like with the GPU block installed.
Does anyone else have a DIY LCS? if so could you please tell me what components you have used? o ye and another thing...
chipset cooling?
is it worth it?
CPU/GPU block
The Radiator
And the setup?
chipset cooling?
is it worth it?
Reservoir before pump, nothing else matters. Go for the shortest tube length possible.
