- 28 Mar 2004
- Newcastle upon Tyne
Hi,
I've just bought this laptop:
Viewsonic Viewbook BMD 130.
I want to upgrade the memory from 2GB to 4, but just cannot find the casing for the memory? There is one back panel that has one screw but when I unscrew it the panel is stiff and feels like it would snap if I tried to apply more pressure.
Has anyone managed to upgrade their memory on this laptop? If so, can you explain how?
Failing that, is it common for laptop memory to be fitted below the hard disk? This panel can actually be removed, but I don't want to mess about with it unless I have a reason.
Any advice appreciated.
