a lot of memory usage
6 Oct 2004
England
im running vista, the only programs i ahve open are
firefox/avg/dumeter/steam and yet my memory usage is running at 950mb!! Thats nearly half my max usuage (2gb memory)
surely this is high?
Nope that's about normal. Don't worry about it. If your PC starts to become sluggish with normal usage then come back ;)
And awaits Bledd. doing the obligatory upgrade to 4GB+ RAM.
Burnsy
http://www.microsoft.com/windows/windows-vista/features/superfetch.aspx
Windows SuperFetch enables programs and files to load much faster than they would on Windows XP–based PCs.
When you're not actively using your computer, background tasks—including automatic backup programs and antivirus scans—run when they will least disturb you. These background tasks can take up system memory space that your programs had been using. On Windows XP–based PCs, this can slow progress to a crawl when you attempt to resume work.
SuperFetch monitors which applications you use the most and preloads these into your system memory so they'll be ready when you need them. Windows Vista also runs background programs, like disk defragmenting and Windows Defender, at low priority so that they can do their job but your work always comes first.
