As I posted in the gym rats thread, I have been lurking for a while and decided to pipe up in a couple of threads.
I now think it would be good to post a log, really to track my progress more efficiently but also for advice and feedback.
I've been lifting on and off since June last year, but since the Jan 2013 I've really started to focus more on my routine and diet. I am quite heavily limited by both time and equipment at the moment, as I tend to do my workouts in about 45 mins over lunch in the gym at work. Equipment wise, the max for the bar is 105kg and dumbells 35kg - though they have put in for more weights (hopefully 25kgx2 and 20kgx2 olympic plates). Failing that, I will have to venture out into the big bad world and find a more suitable gym.
Diet wise, hitting about 2800 calories a day at the moment and trying to keep it fairly clean...well sort of
I'll also get some pics sorted tonight so you can all laugh at the fat guy and I can start visualising my progress
Stats
Height: 6ft
Weight: 94.1kg
Body Fat: 20-25% (needs remeasuring)
Lifts
Bench: 105kg
Squats: 105kg +
Deadlift: 105kg +
General Workout
I will do a three day split on A/B/C and throw in some lighter stuff on the other days - this could be ranything from olympic rings, form work or learning a new exercise (e.g. power clean - nice thread!)
A -
Bench Press
Dips
Fly
Tricep isolation
5-10 minute jog
B -
Squats
Shoulder Press (DB)
Leg extensions
Shoulder isolation
Core work
C -
Deadlifts
Rows (DB)
pullups/pull downs
Bicep curls
5-10 minute jog
Stats
Height: 6ft
Weight: 94.1kg
Lifts
Bench: 105kg
Squats: 105kg +
Deadlift: 105kg +
General Workout
A -
Bench Press
Dips
Fly
Tricep isolation
5-10 minute jog
B -
Squats
Shoulder Press (DB)
Leg extensions
Shoulder isolation
Core work
C -
Deadlifts
Rows (DB)
pullups/pull downs
Bicep curls
5-10 minute jog
