a mATX case with good air flow
5 Mar 2011
Hi to all,
I am going to help my brother sort out a rig during his six weeks holidays which is just around the corner! I have sussed all components out apart from a case, I really need it to have sufficient air flow as well as being to house a GTX 560 (Ti) or HD 6850/ 70. Does anyone have any good suggestions? (And yes, space is as valuable as his bearded dragons in his room.) Thanks!
Or NZXT Gamma, squeezed 2 6950's in mine, lots of fan mounts, good airflow, pretty small, and can be picked up for about £35. Just a heads up though, the top PCI slot has about 10.7" card length clearance, but due to the HDD cage the 2nd and 3rd slots only have about 10.5" card length clearance. So check your card sizes before you buy!
Edit: bugger, I miss-read your post too, the Gamma is a full ATX midi case, so you'll probs find something allot smaller that's tailor made just for mATX boards.
