How does the bluetooth on an E46 work? I was talking to a guy about his car for sale, and he said that he'd never used his bluetooth as it'd only got a holder for certain types of Nokia phones? Is this right? I realise you can probably change the holder (which hopefully charges the phone?) but can the bluetooth be used with a phone in your pocket, or do you have to keep the phone plugged in?
Is there an iPhone holder?
Is there a way of getting a nav equipped car to play mp3's/ipod's/iphones? If so, does it control it on screen?
How many channels do you get on the TV? The standard five, or freeview?
How much should I aim to pay for a hard top / wind deflector, and do they make a noticeable difference to noise etc?
Is there anything that you do to 'care' for a convertible hood?
The guy I was talking to about said his car had adaptive Xenons, the kind that look around corners when you're driving. I thought this was a realatively new thing, and not something that you'd find on the E46? So, is he talking out of his arse, or am I wrong and the Xenons are adaptive as standard, or am I wrong and there were Xenons, and then adaptive Xenons?
With regards to retro fit costs, I've heard it said that you can retrofit nav, but it costs a grand and you have to take the car apart, so I'm not doing that, but how easy is it to replace the standard halogen light units for factory OEM Xenons? Is there anything else to consider, or would I still need the ballast stuff? How much for OEM Xenon's?
How easy is it to retrofit factory bluetooth, and the folding mirrors? How much for each?
Is the drive of the E46 Convertible much different to the Coupe?, I realise that the Convertible will be slightly heavier than the Coupe, and will subsequently lap the ring in twelvety less seconds, but I don't care. I do care about the handling though, and have heard about something called scuttle shake? What is this, how do I notice it, is it really that bad, and does the E46 have it?
Cheers in advance, and apologies for babbling...
