** A MONITOR WITH MORE FEATURES THAN I THOUGHT POSSIBLE!!! ** BenQ XL2430T
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK either BenQ are great at lots of marketing waffle or this monitor has a spec list so long, go make a brew and do some reading:-
BenQ XL2430T 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red /w Flicker FREE Technology @ £319.99 inc VAT
BenQ’s new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
As the world’s leading brand in gaming monitor, BenQ manages to provide more than just the refresh rate feature for different resolutions to reach more levels of optimal refresh rates (100/120/144Hz) with Gaming Refresh rate Optimization Management (GROM), which aims to bring users the incomparable gaming performance. With the gamer-driven GROM that collaborates with Display Mode and Smart Scaling strengths, BenQ offers a total refresh rate solution for gaming enthusiasts.
It is absolutely vital that the XL2430T give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2430T’s Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20v, and swivels left and right to a wide range of angles. Every XL2430T can be your personal XL2430T.
The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2430T is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
The secret is out. Download special gaming presets used by the professional players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from professional gamers will be released in the future so you can always stay on top of your game.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display Mode function, the monitor can be easily changed between 7different screen sizes, from 17”, 19”, 19”W, 21.5”, 22”W, 23”W and 24”W.
If you’re looking to customize your screen size further, you can also take advantage of the Smart Scaling feature. The Smart Scaling feature gives you the flexibility to freely scale the screen content to any custom size. With just one monitor, you can simulate any game play and practice under different display sizes for tournaments. Use the Display Mode and Smart Scaling together to get the possible view for any application or game.
The Auto Game Mode enables the XL2430T to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode.
To save gamers the hassle of having to re-download and reset game modes, the XL2430T allows gamers to store game modes onto a USB flash drive for easy and simple carriage. They can also share their own game modes with everyone via cloud storage or social media platforms. This innovative feature allows gaming communities to share, collaborate and bond freely with ease.
The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
The newly upgraded Display Pilot function allows users to make all the on-screen display adjustments, plus provides them with direct access to the Game Mode Loader feature for downloading and installing the preset display settings of their favorite game or professional gamer’s screen instantly.
Sporting the latest angular, compact base that aligns perfectly parallel to the desk surface and a monitor stand meticulously placed in golden ratio to counter balance the display, the next-generation base stand design offers a new level of stability for the steadiest gameplay – with stringent swivel and shock testing results to prove it. Additionally, the reduced width and depth further shortens the distance between the keyboard and the monitor, bringing you closer than ever to the game.
The aluminum alloy coated monitor stand sends off a sophisticated yet mysterious metallic appeal that conjures up the majesty of the game. On top of that, it is ergonomically optimized with a widened and thickened top handle that’s comfortable to grip, making the monitor much easier to carry from one place to another.
Placing a retractable headphone hook on the left side of the monitor display conveniently puts your headphones within arm’s reach. The material of the headphone hook, which has been upgraded to aluminum alloy, offers extra hardness and strength for improved durability.
Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ’s new Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
Developed in collaboration with pro gamers, the XL2430T has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Specification:-
- Back Light Unit: LED
- LCD Size: 24"W
- Vertical Refresh Rate: 100 / 120 / 144Hz
- Aspect Ratio: 16:9
- Resolution (max.): 1920 × 1080
- Display Area(mm): 531 x 298
- Pixel Pitch (mm): 0.276
- Brightness (typ.): 350 cd/m
- Contrast (typ.): 1000:1
- DCR (typ.): (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170° / 160°
- Response Time: (Tr+Tf) typ. 1ms (GTG)
- Display Colors: 16.7 million
- Color Gamut: 72% NTSC
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack / USB Hub
- Power Supply: (90~264 AC) Built-in
- Power Consumption: (Base on Energy star ): 24W
- (Power saving mode): 0.5W
- Kensington Lock: Yes
- Dimensions: (HxWxD mm) 516 x 571 x 149
- Net Weight (kg): 6.1
- Motion Blur Reduction: Yes
- Low Blue Light: Yes (10 levels)
- Black eQualizer: Yes
- Game Mode Loader: Yes
- Display Mode: 17" / 19" / 19"W / 21.5"W / 22"W / 23"W / 24"W
- Smart Scaling: Yes
- FPS / RTS Mode: Yes / Yes
- Flicker-free Technology: Yes
- Display Pilot: Yes
- Senseye: Senseye 3
- AMA: Yes
- Win7: Yes
- Win8: Yes
- Height Adjustment: Stand (mm) 130(adjustable down to the base)
- Full Specification: http://gaming.benq.com/gaming-monitor/xl2430t/specification/#skip
- Warranty: 2yr
Only £319.99 inc VAT.
ORDER NOW
It looks absolutely stunning to be honest and BenQ are experts with these high-end gaming panels, so I expect it to be exceptionally good! :)
Sounds like I need a PhD just to get it set up!
So, is this like the 2420Z but with more features?
Edit: After a bit more reading, it seems so. Plus an external redesign. Quite tempted!
Still not sure I'd benefit from G-Sync all that much as I'd probably prefer blur reduction/ULMB if anything (realistically probably just play with it off and at 144hz).
A 1920 x 1080 TN 24" monitor with a high refresh rate. And no Gsync. What's the fuss about, don't get it???
If it had g-sync I'd be interested, but without it at that price AOC is destroying Benq.
As for those saying 1080p needs to die, while I agree higher resolutions look nicer, not everyone has enough GPU power to game at higher resolutions unless they turn down a lot of eye candy which kinda defeats the purpose.
Also on a 24" screen 1080p is the perfect resolution for that size, very usuable.
Not everyone has the space for a larger monitor.
4K monitors are obviously going to drive changes in the market, but the biggest change needed it's scaling of elements in Windows and a huge increase in GPU power to run games at those resolutions.
Not everyone has the grunt to power a 144Mhz Display at its 144Mhz.
