Hi Guys,
So you may have noticed over the last couple of hours that a new cooler has become available for pre-order on our site. The Phononic HEX 2.0 Thermoelectric CPU Cooler uses new ways of cooling you CPU to allow your CPU to perform at its best without heat issues.
The Phononic Hex 2.0 is a compact processor cooler with an integrated Thermoelectric heat pump, active-passive dual-tower design, regulated 92 mm PWM fan, software app for Windows, adjustable logo LED along with fantastic cooling performance for Overclockers and CPUs up to 220 watts TDP.
Phononic HEX 2.0 Thermoelectric CPU Cooler @ £109.99 inc VAT https://www.overclockers.co.uk/phononic-hex-2.0-thermoelectric-cpu-cooler-hs-000-ph.html
Compatibilty: Intel 2011 / 115x / AM2 / AM3, 92mm CPU Fan, Quiet Design, Smart Temp Monitor, 1 Year Warranty
The HEX 2.0 combines a proprietary state-of-the-art high performance thermoelectric module with an innovative heat exchanger. The small form factor CPU cooler pioneers a new category of cooling technology. The compact design comfortably fits in small chassis, including mini-ITX cases, while delivering cooling capacity beyond that of much larger coolers.
- Exceptional Temperature Control
- Custom LED Options
- No Water
- Easy Installation for Intel and AMD Sockets
- Smart Electronics Monitor Temp & Provide Appropriate Cooling
- HEX 2.0 performance is compatible with the highest power CPUs on the market, with room for overclocking
- 1 Year Warranty
Features:
- Type: Fan Heatsink with Thermoelectric Heat Pump
- Fan: Integrated 92 mm
- Powerful cooling for overclockers & software app for Windows
HEX 2.0 App:
- Control the amount of cooling the thermoelectric heat pumps provide by selecting the appropriate cooling mode
- Customize the look of your HEX 2.0 by selecting LED colors, effects, or just turn it off
- Keep up to date with the latest firmware for your HEX 2.0 and any new additions to the application
The "Hex 2.0 Dashboard" software application for Windows enables controlling the LED lighting of the logo, updates of the firm- and software as well as the selection of three dynamic cooling profiles.
- Three intelligent cooling profiles: Ambient Mode, Standard Mode, Insane Mode
- Integrated sensors regulate heat exchanger & fan speed automatically
- Quiet Zero Power Mode while idle, but extreme cooling power upon load
- 35 watts maximum energy consumption of the temperature-controlled heat pump
- Micro-USB cable for mainboard header included
Key Features:
- Small Form Factor, High Performance
- Integrated and Swappable 92mm Fan
- Supports TDP Power for Over Clocking Beyond 140W
- Low Noise Design (33 dBA @ max speed)
- Active/Passive Cooling (Using Phononic’s Thermoelectric Technology)
- Integrated Electronic Control Applies Active Cooling only When Needed
- Optional Application Software and User Interface Allows User to Adjust Performance Characteristics
Specification:
Motherboard Connections:
- CPU Fan: Provided connector
- Power Connections: Standard 6-pin AUX graphics cable | Required voltages = 12VDC
- Optional USB Interface: Provided connector
Electronic Control Specification:
- On Board Electronics: Plug in power + fan connector to enable operation
- USB Connection: Enables HEX 2.0 dashboard application for monitoring and customization
Cooler Specification:
- Dimensions: 125 x 112 x 95 mm (H x W x D)
- Weight: 810 grams
- Material: RoHS compliant
Fan Specifications:
- Size: 92 x 92 x 25 mm (H x W x D)
- Connector: 4-PIN PWM
- RPM & Noise Level: Max: 2650rpm (33dBA) | Typical Idle: 1000rpm (<17dBA)
- Air Flow / Max Static Pressure: 44 CFM Maximum / 3.1 mm H2O
Compatibility:
- Intel: LGA2011, LGA 115x
- AMD: AM2/+, AM3+
Max TDP:
- 2011: 140W
- 115X: 95W
- AM2: 220W
- AM3: 220W
Only £109.99 inc VAT.
ORDER NOW
Here is a mini video for teh cooler from the E3 event:
- No Water
- 1 Year Warranty
Features:
HEX 2.0 App:
Key Features:
Specification:
- Weight: 810 grams
Fan Specifications:
Compatibility:
- AMD: AM2/+, AM3+
Max TDP:
- 2011: 140W
- 115X: 95W
- AM2: 220W
- AM3: 220W
ORDER NOW
