In all honesty, I would question anyone who would buy a P67 Motherboard with a non K processor, especially just to run it at stock. That said, as Gharris stated, I don't see why they wouldn't work just fine.
Would you mind explaining what you mean by that please?You can still enhance the Turbo Boost with a P67 motherboard.
Would you mind explaining what you mean by that please?![]()
Thanks for the explanation - appreciatedNot really sure why they've killed overclocking yet allowed a little tweaking and I don't know the exact specifics but.
Say you've got a 3.5Ghz processor that does 3.9/3.8/3.7/3.6Ghz in turbo on 1/2/3/4 cores respectively(as it overclocks further with less cores).
You can tweak turbo for some reason so it will run at say 4.2/4.1/4.0/3.9Ghz instead. You can essentially turn Turbo up a few notches from stock, not entirely sure why they put the option in but there you go.
But its still limited to turbo and won't make much difference when all four cores are loaded. So its miles away from whacking a 3.5Ghz processor to 4.5Ghz and running all 4 cores at that speed while playing Crysis, its better than nothing though.
Thanks for the explanation - appreciated![]()
CheersI'll just add that on the partially unlocked SKUs that you can add 4 to the turbo multi for each set of conditions
