A number of issues with pc
5 Nov 2014
Hello,
I have been having a number of issues with my pc for the last few months. The issues are memory management and non paged area blue screens of death. On top of this games randomly crash to the desktop (garden warfare 2 and the dvision) sometimes when I first turn the pc on and Windows loads I get apps failing to load on startup with errors displayed and browsers error with stop responding messages but a reboot sorts this.
So far I have done the following to try and sort the issues out
- move games to another ssd to make sure it's not the drive causing issues.
- changed sata port and cables
- re applied cpu paste and cooler
- changed pci slot for gpu and tried another psu
- cleared cmos and everything at default with only xmp enabled.
- ran memtest for 8 hours with no errors
- idle temps are 30c and load when gaming don't go over 60c
- done clean inside all of windows 7 and windows 10 but still get the issues
After all the above I think the mobo is on its way out but before I spend 500 odd on a new system just want to get other opinions as if I still have issues after I would have wasted a lot on a upgrade. My pc is a x58 asus mobo with 6gb of ram and a i7 950.
Thanks a a lot
I have garden warfare and garden warfare 2, I don't play these but my son does.
It's on the latest bios but I also get the same issues of crashing to desktop with the division, sometimes it will be fine for an hour or so and no issues then some days it's worse than others.
It's a old system but has done me well over the years. Less demanding games like Lego worlds and other Lego games seem ok if you haven't guessed my son is a Lego fan lol
