Hi
Please help me i am suffering and in 6 months I have still been unable to get my PC running nicely
Puchased a PAQt 5U case acoustically treated who also supplied a Seasonic s12 650w PSU, Xigmatec s1284 with 2 x 120mm 1000RPM fans on the heatsyng. The case has 3 x 120mm fans mid chassis. (www.paqt.co.uk).
The following kit was purchased from OC's March 2009 :
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - Retail
EVGA Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
OCZ 6GB DDR3 PC3-12800C8 1600MHz Gold (3x2GB) Triple Channel DDR3 (OCZ3G1600LV6GK)
Microsoft Windows XP Professional SP3 - OEM (E85-05683)
Powercolor ATI Radeon HD 4870 1024MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Other components attached
Hard drives x 4 (WD Raptor 150gb & 3 xSamung 250 HDs)
RME Fireface 800 Audio Interface
Unitor serial midi interface + other midi kit
Primary use is for Audio/Video recording hence the silent case/kit.
Bios upgraded to latest E758SZ2P and motherboard recently RMA'd
The issue I have is setting the bios correctly as i am getting, what I think, is high CPU temperatures and the configuration for the motherboard and its components.
I ideally want the RAM running at 1600mhz which is the factory speed of the and not really fussed about overclocking.
However, on the 1st build booted straight up and the CPU was clocking 3400mhz and RAM 1066. (Temperature was 50+ and each core between 65-70) - all centigrade!
Reset PC and set default bios which then lowered CPU to 2800 and ram to 1600.
I have been advised on the OCZ forum that the settings for RAM should be :
2:12 8/8/8/24/88/2T Dimm 1.65V QPI 1.35v
Everything else i have left to auto.
At the moment the RAM is set at 1600mhz and the CPU running at 2653mhz... this doesnt seem right?
Basically I need some expert advivce to get the rig running stable. Have used OCCT which blasts to 90*c after 5 mins and stops!
I have attached of the current settings and timings.
http://img3.imageshack.us/gal.php?g=1cpu.jpg
http://valid.canardpc.com/show_oc.php?id=704065
I really do not understand a lot of what I am doing and need a solution.
Hoping some people can help. I have had various conflicting advice re settings and am concerned what us right and what I should do.
I know each rig is different but I am not really looking to overclock, unless the temperatures are lowish.
I have used Arctic Cooling MX-2 Thermal Compound from OC on the base of the cooler and is pretty thinly spread and have 100% isopropyl alcohol to clean if needed to remount. But I have done this several times and still get similar temperatures.
I am wondering if the memory should be run at 1600mhz, however this rate was highly recommendedfor running some of the sample audio streaming applications installed.
The graphics card is mounted on the first slot nearest the cooler but could be moved down, however, I was trying to keep it further away from the PSU fan which blows on the card.
I really need some solid advice on all correct bios settings, i know its a lot to ask but I from reading around it appears that the RAM and CPU are tied in on voltage and speeds etc.
Please help me...it is much appreciated Thanks in advance.
PS Sorry for the squishy JPEG I have limited photo software (infraview and paint) Give me audio and am a whizz..
I am confused and lost
