hi peeps...
just a quick question... acronis true image home 10 wont load from the bootable cd that i normally use (seems to be an incompatability problem with my DFI Dark mobo...) - anyway, just wondering if you get the same effect if you do it from the main program within windows? i've always been dubious about using the program while windows is running...
is there any difference in the image that is created? doing it from a third party perspective (boot media) always seemed the best way to go but that choice has been eliminated for me until they bring out the next update patch (maybe)...
anyone know about stuff like this?
