Hi All,
I have 2 machines in VM Ware. 1 is an XP install created in VM Ware and 1 is my previous Bootcamp partition.
Bootcamp uses a 60GB IDE disk and the native VM uses a 20gb SCSI disk (In terms of physical data both machines have about 10GB in use).
My 2 machines are setup the same more or less (in terms of software). I was using Bootcamp first and then decided to create a VM with same settings (with a view to ditch Bootcamp).
Obviously, I booted the Bootcamp in VM Ware as well and it performs slower/worse than the native VM for a few reasons, which I guessed below:
1) The Bootcamp partition loads 2 sets of drivers, the BC drivers that Apple provide and the VM Tools. The VM native machine only has to load the latter.
2) The Bootcamp partition is using a virtual IDE driver of some sort to access the HDD, The VM machine is using a SCSI driver to access the 20gb hdd. (just like VM on other systems using a virtual SCSI driver over IDE improves disk access etc)
3) Longer bootup times (see reason 1 for explanations).
4) Password required to open the Bootcamp VM, no snapshotting or suspending.
I plan to ditch the bootcamp install very soon as I cannot think of a single reason to keep it. I even watch videos in the XP VM and it works fine. I don;t play any games as such or have not come across any CPU intensive software/tasks that I need desperately that cannot be done in OS X (yet). (I will keep a WinClone image of the machine in case I ever need to go back to Bootcamp).
Finally, XP is not good at all in BootCamp. I have used XP extensively for years and the experience on a MAC in BC is crap tbh. It crashes, hangs, has standby/hibernate issues. Obviously this is down to the BC drivers but it is still not a pleasurable experience using XP in OSX BC if you have used XP on a decent non MAC machine before. In VM it is fine (no crashing
rp2000
