- 22 Sep 2006
This is my first post so bare with me pls,
Firsty my spec:
AMD Athlon 64Bit 3000+ 2.0Ghz
512Mb RAM 333
ATI 7600XT 256Mb
Asrock K8 Board
The gfx card is over clocked bt not CPU.
Firstly Id like to ask if these temps are ok, i use speed fan and im woryd about this core temp, i am thinking that its wrong but i need advice thx,
Temp 1: 32c IDLE
Temp 2: 32c IDLE
Temp 3: 31c IDLE
HD0 : 35c IDLE
Core : 82c IDLE !!!!!!!
Temp 1: 33c LOAD
Temp 2: 36c LOAD
Temp 3: 35c LOAD
HD0 : 35c Load
Core : 84c
I have a Thermaltake Soprano case with defualt fans and setup.
Thx.
			Firsty my spec:
512Mb RAM 333
ATI 7600XT 256Mb
Asrock K8 Board
Temp 1: 32c IDLE
Temp 2: 32c IDLE
Temp 3: 31c IDLE
HD0 : 35c IDLE
 Temp 1: 33c LOAD
Temp 2: 36c LOAD
Temp 3: 35c LOAD
HD0 : 35c Load
Core : 84c
Thx.
