A question about how much memory my OS is using?
4 Nov 2002
England - Leeds
Hi there, please can you help. I have a brand new PC and I have 4gig of ram, in windows it shows up as 4gig of ram, which is brilliant, before I installed windows updates and all my drivers for my hardware and everything it just showed 3gigs but now it shows 4gigs, but anyways I just wondered is the OS actually using the full 4gigs or because I have windows vista 32bit ultimate is it just using 3gigs?
One of my friends said he thinks its using 3.2gigs...so I just wanted to get to the bottom of this question once and for all?
Thanks in advance,
SkScotchegg:D
scotchegg-yup ur friend is correct,just go vista64.if u decide to stay on vista32 then 3GB better than 2GB anyhoo
I was wanting a more spacific answer, like an exact number of how much memory my OS is using or how I can find out?
Thanks in advance,
SkScotchegg:D
Take your installed RAM, deduct the size of your graphics card and the size of your swapfile and that's roughly how much available RAM is left. Usually 3-3.5Gb.
If you want to know how much is actually in use, then have a look in the Task Manager on the Performance tab.
