A question about Linux on USB
29 Aug 2006
South London
A question: If I were to say, install a distro of linux like xubuntu to a large usb pen (talking 8Gb) would I be able to boot and use it off any computer I put it in? I'm thinking of drivers etc here. Thanks for your input!
You cannot simply install an OS to a USB pendrive but you can make a USB pendrive bootable. As said above, it works more like a LiveCD, ie a compressed volume is expanded into RAM to create the environment and you go from there.
I have done it myself a while ago from a Slax-based LiveCD ISO and a special tool to format the USB pendrive (which was from HP) which can be found here:
http://h18000.www1.hp.com/support/files/serveroptions/us/download/23839.html
Google will show you plenty of results if you search :)
