I wish to use the onboard graphics of a core-i5 3470 - can I use any 22nm supported motherboard to use it? or do I have to purchase a certain board/chipset that allows you to use the GPU on the CPU - that is to say, is it possible to get a 22nm supported board that doesnt allow you too use the CPU's GPU and instead forces use of GPU on the boards chipset instead (or PCI-E Graphics Card)...?
thanks
thanks
