- 11 Oct 2005
- Derbyshire
Hi, quick question as in the process of tidying up my computer.
I have 3 120mm fans
1 of them is a 2 wire fan into a molex.
The other 2 fans have 3 wires coming from it, 2= (red & black) into Molex and the 3rd wire, yellow has a little brown plug on it with 3 holes.
Can these plugs fit onto the motherboard (if spare fan sockets) and be controlled, seeing as there is only 1 wire on it.
Or is it best to just leave it wrapped up out of sight.
thank you
I have 3 120mm fans
thank you
