Hi all,
If you have setup roaming profiles, you can prevent certain folders being copied during login using folder redirection. However, when you configure folder redirection, do you simply overwrite the profile folder?
For example, if my profile is stored at...
\\pdc\profiles\james
When I setup redirection of the My Documents folder, should i configure it as...
\\pdc\profiles\james\my documents\
Or should it go to a different share, i.e.
\\pdc\temp_redirect\james\...
Little confused by this. If I should be going to a different share, does this mean everytime a userlogs on, it copies there profile to a different share on my server, instead of just using the original in the "profiles" folder?
Thanks all,
TM
Thanks all,
TM
