- 4 Nov 2002
- England - Leeds
Hi there, you know how on the OCUK shop you can buy just the case, with all the bits in, and some are overclockers and some arent. Well I was wondering are you getting better value for the overclocked PC rather then one that isnt overclocked?
What I mean by that is say they have two PC's that are exactly the same, but one is overclocked, is the overclocked one the same price or more expensive, how do they value the overclocked PC's?
And also the ones that are overclocked, have OCUK put extra measures in place to keep them cooler like surely they have better fans/heatsinks installed for better cooling because they're overclocked?
The reason am asking these questions is because am thinking of buying a PC on OCUK but am not sure weather to stay well away from the overclocked PC's because I know nothing about overclocking or weather they're a great value buy?
Thanks in advance,
P.S. Dont flame me about these questions, just dont reply to my post if you think these are stupid questions, just skip it! Only reply if your going to answer my questions.
SkScotchegg
Thanks in advance,
SkScotchegg
