A Question for Dell U2410 owners
30 Sep 2009
Beccles, Suffolk
Could you please tell me if you can disable the front blue led within the screens settings.
I just noticed its on offer this week, but could not find my answer from googling.
Thank you for the help
They only light up when your hand comes near them, otherwise they are off. You have to touch the actual lights as there are no push buttons. The only light which is permanently on is the power light.
Thank for your help
I really dislike any light within my line of vision, even my sky box is modded
I don't believe there is a better monitor out there from what iv read,
So i will have to make up my mind before wednesday
Thanks for the input anyway
There are a lot of important reasons to choose a monitor, but the LED power indicator shouldn't be one of them in my opinion. So if it bothers you then apply tape over it or use black nail polish/paint (I've done the latter for a home theatre unit) and enjoy the other reasons for the choice :)
