a question for people with skybb
4 Jul 2005
UK
I am moving soon but keeping the same landline number, should I get a MAC code or not?
A few questions....do you get assigned a new IP when the router is reset?
Also, what model is the netgear router they give you?
thanks.
It will be a cease and re provide for the move. Your MAC code is worthless as it will be for your old house.
You will probably either be assigned a new IP every day/week and/or every router reset.
DG834GT ?
The router is a Netgear DG834GT but it uses Sky firmware which doesn't go down too well, but it does its job none the less.
