A question of power...
14 May 2009
Hampshire
Evening all,
My 3060ti arrives tomorrow and I debating changing from using 1 split 6+2 too 2 x single 6+2.
I've used the split cable for all my GPUs over the past 5+ years and never had an issue but have seen a few posts on Reddit where people are advising against it.
As I've got to open up the case tomorrow I thought it would be the prime opportunity to do it.
The only problem I do have is that I don't have 2 single 6+2 cables but I do have 2 split 6+2 cables. The problem I would have if I did that would be that I would have 2 ends just dangling there. The case has no window so not fussed on looks but not sure where that stands on 'safety'!
Any suggestions or should I just keep using the split cable?
For reference, I have a Corsair AX760 Platinum PSU and using the supplied cables.
Thanks!
The 3070fe only used a single 8 pin cable going into the custom 12 pin in the board. I would not expect the 3060ti to use more power so a single cable should be fine.
