A question of space (will it all fit)
16 Jun 2005
Back in the UK
OK this is the spec im considering but will it all fit and work?
Antec Nine Hundred Ultimate Gaming Case (£68.14)
Is this case deep enough to take the Gcard?
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit (BL2KIT12864AA1065) (£135.11)
Best currently "in stock" ram when I actually place the order i may change it to Geil Black dragon if its in stock, is this a good change?
Scythe Infinity Heatpipe CPU Cooler (Socket 478/754/939/940/AM2/LGA755) (£29.36)
Again will this fit on the Mobo without interfering with the heatsinks on the chipset? would there be any case issues due as well?
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM - 1Pk (66I-00788) (£64.61)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) (£88.11)
Will the cables be long enough? is this a good stable PSU?
EVGA GeForce 8800 GTX KO ACS3 SILENT 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (768-P2-E837-AR) (£422.99) Will it fit in the case? I assume the PSU will be enough to drive it.
Asus P5K Deluxe WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard (£146.86)
I want to use a RAID0 setup but understand the Gcard will block some of my SATA ports, is this still possible?
Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB) - Retail (£176.24)
If G0 are available when I order I will pick one up but if not im not going to delay my build.
Samsung SH-S203BEBN 20x20 DVD±RW Dual Layer Serial ATA ReWriter (Black) - OEM (£39.92)
After pluging 2 Hds in, in a RAID0 config these will still be on on the same controlers wont thay? I know there is 6 ports some of which will be blocked by my Gcard and i am concerned how this will all work out.
Arctic Silver 5 Thermal Compound (3.5g) (£7.04)
No comment
Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache - OEM (£126.88)
2 drives in a RAID0 setup are these still the best choice HD for 500gb drive?
Anyone got any comments or advice?
It is going to be a gaming rig mainly, and i will be doing low levels of OC once im 100% sure of stablility at stock.
