- 15 Jan 2004
- Doncaster
Right. You know those little black spots you get on all areas of your car that can be removed when washing, but usually take quite a bit of elbow grease? Best removed using a wash mitt's reverse side, or your fingernail, and when you do the black dot often leaves a small brown-ish stain that you've then got to remove.
Hopefully you know what I mean. What are they? Is it just bits of industrial gunk? They're possibly about the most time-consuming and annoying part when it comes to cleaning my car.
