A quick guide on how to get dolby for real tek audio
23 Feb 2009
Bournemouth
Hi all
This is how to get dolby audio for real tek works for me as you can see a picture of my real tek control box.
follow this https://www.techpowerup.com/forums/...d-dts-interactive.193148/page-37#post-3360667 as i did,
heres a picture
I'd like to point out that this was done on windows 10.
Sorry for late reply.
Motherboard is a cheap h81m-s2h socket 1150.
If your after 7.1 virtual surround sound then go to http://www.razerzone.com/gb-en/surround
Just install that saves you a lot of hassle if you want 7.1 virtual surround.
Should work on any audio input device .
If you ask if this sounds the same as dolby then yes, yes is the answer.
The second picture, its the razer app that caused those bars to be like that happens when i turn it off and then test it, when it's on it doesnt give the bars, but works universally with everything, but not when it's off, just the nature of the two programs, flows through the u7 to give surround so it should do the same with any other sound setup.
The way it sounds well compared to bog standard stereo i am able to pinpoint sounds more easy then normal stereo, its the way it is structured.
