A quick speedfan question.
2 Apr 2004
hello all
I have a quick speedfan question.......
i have it set to auto adjust the fans when my cpu hit 40c, the problem i have is they set to 100% when it hits that temperature,
is there anyway to set triggers like 30c = 60% 35c=70% 40=80% or a gradient.
its a shuttle SN25p btw if that makes a difference.
You can set the warning temp, this is the temp at which it will spin corresponding fans at full speed. Its in configure/temperatures.
The only problem is, both desired and warning temps are not saved and revert to default when you reboot, or at least i haven't found a way to save them...
If you want to draw your own speed/temperature graphs and such you need an mcubed t-balancer fan controller.
