jellybeard999 said:just gut a 120mm fan and bolt it all together...
rad-guttedfan-casefan ...
thats all it basically is
Mikey1280 said:Or if you dont have any knackered fans buy some 99p ones. Then run them at 24v volts for a day and theyll soon be broken![]()
feriso said:Ah sod it - best just use that bit of ammonium nitrate (+ a few bits) to clear out the middle![]()
