- 13 Apr 2013
- La France
I'm looking for a fan solution to cool a rectangular RF test chamber of approximately 1/8 of a cubic meter. As it sits in a room which is held at 22˚C, finding cool air to force into the chamber isn't an issue.
Conveniently, the chamber has mounting locations on either side for a 92mm case fan.
The problem is that, for RF isolation requirements, these mount locations consist of a grid of 3.5mm holes piercing the 5-6mm thick sides of the chamber.
Even using static pressure fans, having the fan mounted against a surface which blocks 75-80% of the airflow means that there's very little cool air being pushed into and extracted out of the chamber.
I'm guessing that some sort of stand-off ducting is the answer, but my Google attempts to find something suitable has failed.
Any ideas?
Any ideas?
