I have a watercooled rig. The radiator in the loop can only be described as "Ford Orion".
Just to settle any uncertainties there, it's a car radiator from a Ford Orion car, and it sits on my desk.
Anyway, the problem is that although it's extremely good at dissipating heat, it can't quite cope with the OCd 8800GTX and the E6600 @ 3ghz. On hot days I have a small desk fan pointed at it.
Basically I want to find a big fan that I can bolt to the front of it. the fan blades should be up to a diameter of 12 inches and the chassis shouldn't be much bigger.
This thing has to be QUIET! The whole idea is almost pointless if it isn't quiet. Bearing in mind this rig runs passively with the CPU/GPU at around 55C under full load, I need very little more than a light draft to be created.
The obvious choice is a car radiator fan (haha), but afaik they're quite noisy and I don't know how well one would work if undervolted.
I have no reservations regarding input voltage, that's easy to manipulate.
Cheers!
Cheers!
