A really silly question, DVI cables
13 Oct 2006
Surrey
But do most monitors come with a DVI cable in the box nowadays?
When i bought my acer a few years ago it came with cable included, but most sites dont list whats in the box. If it helps im after the samsung SM22Bw
Cheers
Most do come with a cable, your best bet is to ring up overclockers and ask to make sure :)
As above but you are best checking by reading what's on the box if you can get to one :) By dvi do you mean hdmi as this is what came in my box but I had to add a dvi to hdmi convertor. The box also came with a vga cable but who is going to use vga if you can use hdmi?
If it's the 223bw then:
Reviewed by: Dan Joplin
I got mine this morning, no dead pixels, fantastic colours and awesome contrast. This beats my old 18" CRT hands down.
It comes with a UK kettle cable, a US kettle cable, a DVI cable and a VGA cable. An amazing product for and amazing price.
Buy it now.
Found this under reviews next to its specs at yours truely overclockers.co.uk
I got a DVI cable with my 2232BW, I also got one with a Viewsonic screen that I bought about 2 years ago. I'd be surprised if you got a DVI screen without one.
