A Resolution Question
11 Nov 2012
Hi All,
I've about to receive my 3rd screen to attach and make use of for Surround screens. Lovely indeed.
However, is it possible to run all 3 screens within games at 720p, rather than 1080p?
Hence, would I be correct in saying that this would be a resolution of: 3840×720?
For example, could I run that resolution against games to reduce the raw power required from a GTX 680? Improving frame-rates in the process.
Thanks
Im not sure if the nvidia software allows you to set a custom resolution. If it does then this would be the way to do it. Unless of course there is an 720p resolution option already in the preset options.
If your using less pixels then im sure the power requirement would be relatively less too.
Please feel free to correct me anyone if im wrong.
