A Router question (I've messed up again)
You may be able to run your old router in bridge mode, it will act like a modem.
It depends what your old router is :)
If you've received the router within the last 14 days you can send it back, get a DGN3500 (gigabit) / DGN3300 (dual band wireless) instead.
you can use the old routers modem either:
1. if the old router supports acting as a bridge use that.
2. add the new routers ip to the DMZ on the old router.
