A sandwich style case a bit deeper & a SFX PSU spot under the MB?
19 Oct 2002
Like the SGPC K40, my card is about 1 mm to big of what it says the GPU legnth should be. I have EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR, anyway most of those style cases have the PSU in front of the MB, weird IMO.
If your card is 1mm too long then it may actually fit. Manufacturers have to allow for certain tolerances thermally so the size limitations aren't always black or white.
It would be best to see if someone has managed to fit a similar card (if not the exact same one) into the case, if that's the one you want to go for.
