Hi all,
Im looking to upgrade my machine and would like to ask some advice. This is my current setup:
CPU = Intel Core 2 Quad Q6600 - Was Overclocked
Motherboard = Abit IP35v
Case = ANTEC 900
GPU = Nvidia Geforce 8800 GTS 512
OS = Windows 7 Pro
Ram = x4 1gb DDR2 Corsair 240pin 800mhz
Cooler = Freezer Pro 7
HDD = WD 7200rpm
1. Is there any performance benefits from having two video cards ? As i will be using Houdini and am told it is GPU based.
2. What are the best motherboards available for my CPU ? As im looking to upgrade the ram to either 16gb or 24gb to increase rendering speed, can my cpu handle this amount ?
3. Is DDR3 ram better than DDR2 as the latency is higher and does more mhz mean its faster ?
4. Is it worth upgrading using the Q6600 or is it as cheap to buy a new cpu in a bundle ? Looking for the fast rendering speeds as i will be rendering millions of particles.
If anyone can suggest setups for £100 - £200 / £200 - £300 /£300 - £500 / £500 +
Cheers
David
Case = ANTEC 900
OS = Windows 7 Pro
HDD = WD 7200rpm
Cheers
David
