A SFF like my system?
19 Oct 2002
It would be cool to have a system about the size of a N64 as good as the one I have now, but getting ready to move from this cursed town. Need to save $. System is
EVGA. nForce 650i ultra Intel Core 2 Duo Wolfdale E8200 2.66GHz
6MB Cache Dual Core 1333MHz 2 Gig DIMM-DRAM NVIDIA GeForce 8800 GTS with 512 DDR3 memory (PCIe 1.00 x16) 2 HDDs & 2 DVD drives.
If you used 2.5" HDDs and limited yourself to a 5570 and one optical drive you could do it. There are some decent small book style cases.
But shrinking a system and saving money while doing it?
generally going small puts up the price abit
so saving money will be difficult.
one option could be to get a slightly bigger micro-atx case. Then u'll be able to get a small motherboard with simlar specs and use your existing componants.
or, if you really want a small case, how about this
http://www.overclockers.co.uk/showproduct.php?prodid=MB-004-ZT&groupid=701&catid=5&subcat=1436
then you can use this mitx motherboard
and get an i3 cpu and ddr3 to go with it and try to sell your existing componants.
u'll need a low profile graphics card thou, like
http://www.overclockers.co.uk/showproduct.php?prodid=GX-226-SP&groupid=701&catid=56&subcat=1699
althou i doubt a full system would work out all that cheap
Link 1 & 2 are the same. :)
