6-0+1=?
Now at first glance this is 7....wait wait, let's go to the root! The original sum is 6-1x0+2/2. Now the order of operations dictates that brackets, index, division, multiplication, addition then subtraction is the order you work out this sum.
So 6 - (1x0) + (2/2)
= 6-0+1
But if you use BIDMAS (or BODMAS) should you not do the addition first which makes the sum 6-(0+1) making the answer 5?
Not so simple now? Hmmmm!
= 6-0+1
