- 13 Mar 2005
I have just put the computer together, everything was working fine, windows xp pro installed, great.
Then I tried to install the software for netgear wireless, which works fine on this computer, but when I plugged the usb reciever in the screen went greenish, I mean you could still see the desktop, but everything was sort of greeny yellow.
I stopped, unpluged the usb, restarted, uninstalled the netgear wizard.
Now the desktop has moved about 1/2" to the right, it works just fine but the mouse disapears off the right of the screen, like it thinks there should be more to go(if you see what I mean)
Any ideas? I just installed
Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (CA-048-AN)
Asus A8N-VM CSM Micro ATX (Socket 939) PCI Express Motherboard (MB-119-AS)
AMD Athlon 64 3200+ Venice 90nm (Socket 939) - Retail (ADA3200BPBOX) (CP-118-AM)
GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL)
NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-035-NE)
(£23.44 Including VAT at 17.5%)
Ahead Nero Express v6.6 - OEM (SW-000-NR)
Microsoft Windows XP Professional Edition inc. SP2 - OEM - 1Pk (E85-04026) (OS-002-MS)
OcUK Value Floppy Drive - Black (HD-001-OK)
(£6.99 Including VAT at 17.5%)
Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM (HD-023-SA)
The monitor is a Benq fp91g 19" tft
I would be very grateful for any help
Thanks
Thanks
