Today i installed crysis again just to gawk at the graphics
. I applied the 1.2 patch and by default i had everything at very high in-game and i set the resolution at 1600x1024. The fps were high enough for me to enjoy gameplay but about 30 minutes into the game i started to experience stutter and my fps dropped dramatically to an unplayable level.
Now, if i remember correctly i never had this problem when i first played it a while back. I read the patch notes and it said that memory leaks were fixed but it only said leaks when AA is on, i did not turn AA at all. Has anybody experienced this problem? If so, could you please share the solution if you did find one.
Thanks
. I applied the 1.2 patch and by default i had everything at very high in-game and i set the resolution at 1600x1024. The fps were high enough for me to enjoy gameplay but about 30 minutes into the game i started to experience stutter and my fps dropped dramatically to an unplayable level.Now, if i remember correctly i never had this problem when i first played it a while back. I read the patch notes and it said that memory leaks were fixed but it only said leaks when AA is on, i did not turn AA at all. Has anybody experienced this problem? If so, could you please share the solution if you did find one.
Thanks
