Hi there
Thought I'd pop into work on a Saturday and do a bit of crazy deal on this card for you guys:-
MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
MSI's GAMING lineup gets a big expansion with all new AMD SKUs in the shape of the R9 280X GAMING, R9 270X GAMING and R9 270 GAMING. Kept cool by the familiar Twin Frozr IV Advanced, the MSI GAMING graphics cards come bundled with the MSI GAMING APP, which is an easy tool that takes all of the fuzz out of overclocking and gives a simple one-click solution to get more performance out of your graphics card. Stability and lifetime are never an issue either. With custom PCBs designed for higher efficiency the GAMING cards remain cooler while the Military Class 4 components used ensure high stability while gaming.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1000MHz
- Boost Clock Speed: 1050MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6000MHz
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1x DVI + 2x Mini-DP + 1x HDMI
- Power: 250W TDP
- Dimensions: 269x128x34mm
- 3yr Warranty
Was [£249.95] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
Price goes back up Monday afternoon, though were expecting them to sell out before then, be quick and grab one, forum members getting the first heads up.
Specification:-
- Power: 250W TDP
- 3yr Warranty
ORDER NOW
